This is from their Facebook page and I cant find a thing on their web site.
Below I will give some advice , I hope they will help you. Decals our production Immersed very small thickness , they are thin . And it is very flexible . Frankly, I think it's a big advantage. But it is precisely this quality requires Bole accurate translation process.
1. Do not place in water carved elements on blue paper for a long time for our decals enough 5 - 10 seconds maximum . Then put them on a clean surface ( I use an edge of the water tank or saucer) . After a min...ute - half a colorful picture can be easily shifted from the backing paper .
2 . Do not take the decal with tweezers . In place of the transfer with a small brush , apply a liquid MicroSet. Bring soaked paper element to the place on the transfer model and easy sliding motion move it into place. It should , how-to leave the paper.
3 . Remove the remaining water and a special liquid with a cotton swab . Secure decal , causing her brush MiсroSol not a large number .
4 . I do not recommend immerse cut several items at once. You may not be able to move them and colorful elements will separate from the backing paper .
I hope that with patience and some skill you get all fine . Results of your work will please you .
