Which solution more likely to ruin decals?
Posted by djrost_2000 on Wednesday, March 17, 2004 9:49 PM
Gearing up for summer modeling and wondering which solution would be more likely to ruin decals, Microset/sol or Solvaset/sol.
Thanks,
DJ
Posted by rjkplasticmod on Thursday, March 18, 2004 6:18 PM
In my experience, Solvaset is considerably more aggressive than the MicroSol/Set products. Most modern decals don't need the very aggressive setting solutions and may have an adverse reaction to them. I always start by using MicroSet ( blue bottle ) and only use MicroSol ( red bottle ) if the decal needs more assistance in conforming to the model surface. In any case, it's always wise to test a decal sheet by using a non-essential decal and testing it before applying major decals.
Posted by djrost_2000 on Thursday, March 18, 2004 9:52 PM
Rick,
Thanks for the reply. I'll try Microset/sol and the techniques you listed.
DJ
    May 2003
Posted by qmiester on Thursday, March 25, 2004 9:18 PM
DJ
As you go on in this hobby you are going to find decals that certain solutions will have absolutly no effect on and other that they totally destroy. You're going to have to experiment to find out which effect your solution does to the decals you want to use. This is true of both OEM and aftermarket decals. Between Micro Sol, Micro Set and Solvaset, I can get about 95% of my decals settle ok.
Back in 1988 (November isue I think) FSM ran an article by Paul Boyer on decaling which had a chart showing the effect of all the decal setting solutions available at that time on the various decals furnished by kit manufacturers and a number of aftermarket decals. Personally think its about time an updated chart is published. How about it FSM?
Quincy
Posted by MikeV on Sunday, March 28, 2004 12:50 AM
Rick,
All I have is Solvaset and I have never had a problem yet with any SuperScale decals but that doesn't meant I won't. [:0]
So would you recommend I get some MicroSet/Sol instead or can the Solvaset be weakened with water?
Thanks
    May 2003
Posted by qmiester on Sunday, March 28, 2004 10:03 AM
Mike,
If it works for you, then don't change it (if it ain't broke, don't fix it). Think you'll find that you can dilute Solvaset with water.
Quincy
Posted by MikeV on Sunday, March 28, 2004 10:20 AM
Thanks Quincy.
The reason I asked is because I have been away from modeling for several years until recently and I was curious if newer decal companies like Twobob's and others tolerate stronger setting solutions like Solvaset.
I always test a decal that I don't need on an old model that I have to see if it is compatible though. Wink [;)]
Posted by rjkplasticmod on Sunday, March 28, 2004 12:25 PM
Mike, if you have success with Solvaset and test it on each sheet then it may work fine for you. Iv'e had a few disasters with Solvaset so I avoid it. I prefer the MicroSet/Sol products because they work well for me. Also, I use a lot of Aeromaster & Eagle Strike aftermarket decals and those are designed to work best with the Micros.
Posted by MikeV on Sunday, March 28, 2004 7:50 PM
Thanks Rick.
I guess it might be a good idea to pick some up in case the Solvaset is too strong. You can never be too prepared for disasters. Wink [;)]
