For a good cause
    April 2012
For a good cause
Posted by pianodog on Wednesday, March 1, 2017 10:08 PM
Side ViewHello everyone,
I have a project of building a Bonanza Beechcraft  This plane belongle To my cusing and he was killed in it. I need your help to find de best place to get the decals for the registration number. Is you could assist me with this I'll be very thankful
On The Bench:
Hasegawa Egg Plane F14 Tomcat
Moebius Penguin
Moebius Robin
Meng WWT-001 Tiger I
Meng WWT-002 Sherman
    January 2009
Posted by fermis on Wednesday, March 1, 2017 10:48 PM
I can't help you with a source for decals, but since you are only dealing with two colors, you could spray the plane in white, mask for the red and just cut the letters out of tape/mask and then spray the red.
That's exactly what I had to do when I built a Bonanza for a guy that's based at the airport I work at. Coincidently, the next flight he took, after I had given him the model of his plane, he forgot to put the gear down and belly landed it. It has since been repaired and is still flying.
Posted by Don Stauffer on Thursday, March 2, 2017 9:52 AM
That would be an easy decal to do with inkjet decal paper.  You may even be able to do it from that picture with some graphics editing software.  Paint the plane white, as the above poster suggests.  On the decal, inkjet printers print white as clear, so the white would show through the red where the numbers are.
Posted by docipaul on Tuesday, March 14, 2017 5:31 PM
    January 2009
Posted by fermis on Tuesday, March 14, 2017 5:52 PM
    April 2012
Posted by pianodog on Tuesday, March 14, 2017 9:39 PM
docipaul
I have no words.... thank you so much and your name will be added to the plate
for you to copy and print, just need to resize if needed.
On The Bench:
Moebius Penguin
Moebius Robin
Posted by docipaul on Friday, March 17, 2017 5:45 PM
Happy to help Wink
    April 2013
Posted by KnightTemplar5150 on Saturday, March 18, 2017 2:35 PM
That was a very kind of you to do, Docipaul - well played, sir!
