Acrylic clear over Lacquer ?
    June 2017
Posted by Mars on Wednesday, December 13, 2017 9:13 AM
I have a Titanic hull painted with Humbrol emamel satin white, Humbrol enamel satin coal black and Humbrol enamel satin red. I used Testors Lacquer gloss clear on the decal spots. Decals are on and I need to cover them with a satin clear. I thought I had Testors lacquer satin clear but I looked before applying and its Testors satin clear 79501, which I think is acrylic. Can I use acrylic over lacquer?
Posted by Don Stauffer on Wednesday, December 13, 2017 9:18 AM
My guess is it will work, but why risk it, when a test is easy.  Spray some of the glosscoat on a piece of scrap plastic, then give it a shot of the dull clearcoat, and see what happens.
    June 2017
Posted by Mars on Wednesday, December 13, 2017 9:22 AM
Sounds like a plan, thank you
    November 2008
Posted by plasticjunkie on Thursday, December 14, 2017 10:11 PM
You can spray acrylic over lacquer and lacquer over acrylic. The acrylic needs to be cured say at least 3-4 days. I shoot Testors clear flat lacquer over cured Future all the time.
 GIFMaker.org_jy_Ayj_O
    October 2009
Posted by JacknewbIII on Wednesday, December 20, 2017 12:28 PM
I just did this with flat acrylic MM testors over MM lacquer through an airbrush and it looks fine (including over the decals).
    January 2014
Posted by Silver on Saturday, March 24, 2018 6:53 PM
It is best to use the same product on the model.Clear costs are not hard to get.If you use the mix of both types .Use the acrylic first then the enamel.Remember that enamel never dries.Only to the touch.Acrlic dries hard and fast.
