Josh, since you mentioned using Future as your under-coat, you should also be aware that Future--or any other acrylic finish, for that matter--can sometimes 'spot' or turn white-ish when setting solutions are applied over them.
The 'fix' is easy: first, use as little of the setting solution as possible...and blot away any excess; then, when dry, just brush a little more of the Future over the discoloration. It will usually disappear just like magic!
Good luck.
