How to apply the tiniest of decals..
    June 2019
Posted by Cj2785 on Wednesday, July 17, 2019 3:37 PM
Hey all, how do you reccomend applying extremely tiny decals on 1/72 plane? Thanks.
Charles Johnson
    September 2012
Posted by GMorrison on Wednesday, July 17, 2019 4:14 PM
Hi Charles,
Be sure to apply them to a glossy surface.
Try not to involve too much water or sol and hold the decal down while you wick off the wet.
When placing a series of decals right next to each other, try to take time between each to let them set one at a time. Like a day.
Some decal sets are a little crazy. You really don't need to add every stencil to a jet unless you feel like it.
Posted by gregbale on Wednesday, July 17, 2019 4:59 PM
A good pair of cross-lock needle nose tweezers is invaluable.
Greg
George Lewis:
    April 2015
Posted by Wolfman_63 on Thursday, July 18, 2019 4:06 AM
When I did my 1/350 Aircraft Carrier I built all 86 aircraft and made my own decals. I found using a damp 0/5 paint brush perfect for applying the very small decals. It worked so well I now have 3 different size paint brushes I use exclusively for decalling.
1/350 A-7's
Website:
David's Scale Models - https://www.davidsscalemodels.com
    July 2008
Posted by Est.1961 on Thursday, July 18, 2019 4:44 AM
Nail biting patience while eagerly anticipating the finished result. Many the slip between cup and saucer.
Posted by Don Stauffer on Thursday, July 18, 2019 8:39 AM
I am in the midst of applying decals for 1:700 carrier planes.  Wow, are the stars tiny.
I had been applying them with fine point tweezers, but that has chipped a few decals.  I am now putting the paper against the aircraft surface and using the tweezers to push the decals onto the aircraft surface.  That is working better.
    May 2013
Posted by hogfanfs on Thursday, July 18, 2019 9:35 AM
Wolfman_63
+1 I use paint brushes too.
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    May 2019
Posted by Galatians 2:16 on Saturday, July 20, 2019 4:56 PM
Wolfman_63
1/350 A-7's
Incredible work Wolfman_63! How did you make those decals?
I’ve used tweezers as well on larger decals, but I think I will have to try the damp brush method now.
-Snail
 Snail
Posted by Tojo72 on Sunday, July 21, 2019 8:11 AM
I carefully use the tip of my #11
Those A-7 's look outstanding
    April 2015
Posted by Wolfman_63 on Tuesday, July 23, 2019 3:59 AM
Galatians 2:16
-Snail
I just gathered photos of the actual aircraft and they scaled them to 1/350. I did it for all 86 aircraft. I also built one of each squadron in 1/48 scale  and used those for any images I could not find on the internet. You can see the entire build of the aircraft carrier at https://davidsscalemodels.com/build-log/1-350-uss-carl-vinson/  There are many close up photos of the aircraft getting decals.
F-14's
Here is one of the two sheets I made.
Decal sheet 1
Website:
    June 2017
Posted by UnwaryPaladin on Saturday, July 27, 2019 10:22 AM
Tojo72
I use my blade too. Then roll a Q-tip over them to press them into place and push out the water under the decal. Or if they will not be seen (black stencil lettering against olive drab) I don't put them on.
