Micro Sol paintwork damage
    October 2019
Posted by Pete North on Tuesday, October 8, 2019 5:30 PM
Been trying to use setting solutions on decals. Tried Humbrol Decalfix which destroys paintwork so someone recommended Micro Sol which is even worse. Is there any way to repair this damage and are there any solutions that do work?
Sol
Posted by Tojo72 on Wednesday, October 9, 2019 9:50 AM
Micro set and Micro Sol do work,I have never had that problem in 20 years of use.Can't say what caused your problem,I do use it sparingly,not flooding it on the model,just a few drops on the decal only,and I blot any excess off quickly.
    July 2018
Posted by Tickmagnet on Wednesday, October 9, 2019 12:40 PM
From the way it's all spread out it looks like you are using way too much solution. Unless that happened as a result of attempted clean up. Is it directly on paint, if so what kind or did you clear coat first. If you clear coated what did you clear coat with? Not that I can help but this info would assist greatly.
Posted by gregbale on Wednesday, October 9, 2019 3:53 PM
From your photo, it looks like the damage is to your clear-coat, not your paintwork.
Not sure what you used, but acrylic clear-coats in particular can experience that kind of 'blush' or frosting with any decal-softener or setting solution (or anything else with H2O in it), under certain conditions.
Before you strip anything, try brushing a little of your clear-coat over the hazed area. Often that alone will restore the clarity of the area. (Happens all the time with the Future and Solvaset I use, and always disappears when a little more Future is brushed on.)
Good luck!
Greg
George Lewis:
    May 2013
Posted by Greg on Wednesday, October 9, 2019 4:41 PM
I'm wondering same as Tickmagnet; did you use a clear barrier coat?
Like Tojo, I've used Microsol for years with no problem, but always over a barrier clear coat (acrylic and solvent based, both). I have no idea what might happen directly on paint.
If you did use a clear coat, then I'd lean towards Greg Bale's comments.
Hope you get this sorted, late in the build is a discouraging time to have mishaps, isn't it?
    October 2019
Posted by Pete North on Wednesday, October 9, 2019 7:56 PM
I've used a Humbrol gloss coat. Seems ot be the done thing for the application of decals followed by a matt coat. Not had any success with decal solutions. Even applying directly to paint it still damages the finish. I've managed to correct this by dabbing the area with a cotton bud with the green paint and another layer of varnish over area. Not ideal. The one thing I can say for decal solutions is that I'm now becoming adept at restoration work.
Thanks for your advice.
    July 2014
Posted by Bakster on Thursday, October 10, 2019 12:18 AM
Yeah it kind of looks like you used too much. I have experienced a similar issue when I used too much. As a result of that I apply solution only to the decal film, and not to the surrounding area. And like Tojo said, use it sparingly; you don’t need much for it work.
Lastly, I had seen some people reporting issues with Humbrol clear, paticulary when used to coat canopies and such. They are reporting a frosting effect. Could this be related, not sure.
    July 2004
Posted by stikpusher on Thursday, October 10, 2019 10:36 AM
Pete North
If you get this happening again, shoot a layer of your clear gloss coat over the affected area. I have had a worse look than that with Solvaset and Future. I was told to apply another gloss coat over that, and boom, cleared it right up. The proceed to your final top coat: flat/matt, satin, semi gloss or gloss once you are ready.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2014
Posted by Silver on Friday, October 18, 2019 2:06 PM
Micro Sol or any solution will ruin surface applications if you use any future or glo products.Add a few drops of water to any decal settion solution before starting.If using enamel products.Let the enamel sealer dry for about a week Or longer.If the surface is tacky ,do not start.Polish the surface.
    October 2019
Posted by Pete North on Tuesday, October 29, 2019 4:28 AM
I'm really quite puzzled. Modellers seem to take the view that you have to do a gloss coat to apply decals. I've tried this technique four times now but it doesn't stop decal silvering with or without a decal solution. Microsol just left residues and Decalfix eats any paint. There has to be something that works?
    May 2013
Posted by Greg on Tuesday, October 29, 2019 8:48 AM
Hard to tell from the photos in this and the other thread you just started today, but your gloss coat doesn't look glossy. Is it? If perchance you are spraying it on too dry, you will end up with a pebbly finish that won't protect against silvering.
That said, this doesn't really look like silvering. It looks like what you are saying, the decal solution is attacking the underlying barrier coat.
Perhaps more to the point, how long are you letting that gloss barrier coat dry?
Posted by Don Stauffer on Tuesday, October 29, 2019 9:39 AM
I consider decal solvents emergency tools.  Usually you do not need to use them.  However, if you do use them you must use them with care.  They can ruin a decal with the slightest mis-step.
    July 2004
Posted by stikpusher on Tuesday, October 29, 2019 11:14 AM
Pete North
My next question for troubleshooting would be what decals are you using? Not all decals are alike in their quality. Some kit decals are pretty bad. Most Aftermarket decals are good, but again vary in different aspects.
If you’re having no luck with traditional methods, you may want to try trimming off the clear edging film with an xacto. Slivering (That is visible) is just air bubbles trapped between the decal and the surface. Decal set over a glossy surface goes a long way to reducing or eliminating this. Blotting the decal down with a damp soft cloth after giving the setting solution time to work helps as well. Solvents do not need to be applied generally unless you have a complex surface underneath the decal- compound or complex curves, corrugations, louvres, etc. on a simple basic flat surface like the wing you showed above, there is really no need for a decal solvent. Setting solution and blotting should handle that job with no problem.
       - Plankton
LSM
