Applying Decals
    July 2016
Applying Decals
Posted by Tanker45 on Wednesday, October 16, 2019 7:50 AM
Hello all!
I'm curious as to what you all do for applying decals.  I model armor and quite often I get the decals nice and flat but still can see the edge of the film, even after several coats of clear.
I have used stencils to replace some of the markings but still rely on the kit supplied decals for numbers, etc..
My process is gloss, decal with microset/microsol, gloss again, apply flat.
Any suggestions would be appreciated!
Posted by Don Stauffer on Wednesday, October 16, 2019 9:02 AM
Tanker45
Hello all!
I generally do not gloss again after applying the decals if I want a flat finish. I find flat clear coats work fine directly over the decals.  If I want a more weathered finish I may airbrush a lighter or same color, very light coat, over decals.  This sometimes hides edges a bit better than just the clear flat.  So it depends on subject and decals.  I generally do not use decal solvents unless there is a real need to, like a compound curve area.  Solvents are tricky and can really mess up the decal if you are not careful.  I do generally use the setting solutions, however.
Posted by Tojo72 on Friday, October 18, 2019 5:24 AM
Try to carefully remove as much film as possible close to the decal with an X-Acto knife
    July 2016
Posted by Tanker45 on Friday, October 18, 2019 7:41 AM
I usually try to get as close as possible.  I'll keep at it!  Thank you!
    July 2016
Posted by Tanker45 on Friday, October 18, 2019 7:43 AM
Thank you!  I'll give that a try!
