Unfortunatly, styrene plastic is not totally opaque, and you can see a bit into the plastic. This effect can make the decal appear to float above the surface a bit. Clearcoating helps, but the result still shows the translucence of the plastic. I have sometimes glosscoated or dullcoated small parts right on top of the plastic, but i would not leave a large area with no base coat.
