Decals will not slide once applied
    April 2017
Posted by KarlK on Sunday, August 23, 2020 10:26 AM
I am currently finishing Revell's 1/25 scale Mustang Boss 302. I have painted with Tamiya TS-56 lacquer and used 3 coats of Tamiya TS-13 clear. It looks great. However, when I apply the decals to the body they instantly stick and are VERY difficult to move around and adjust alignment. When I apply Micro set before applying the decal the Micro set just beads up. Am I doing something wrong or is it just the Revell decals? I have been applying decals for 30 years and have never run into this problem.
Posted by Tojo72 on Sunday, August 23, 2020 1:45 PM
When they get stuck, I will add some water to the decal with a brush and that usually loosens them up to be able to move them around.I find the that the Set will do that sometimes,just add a little water.
    September 2012
Posted by GMorrison on Sunday, August 23, 2020 2:03 PM
You did a good job on the surface prep. I would guess it's a problem with the decals.
Water is the trick.
    March 2015
Posted by JohnnyK on Sunday, August 23, 2020 3:38 PM
I add a drop of dishwashing detergent to my decal soaking water. That usually helps make the decals slide.
    July 2013
Posted by modelmaker66 on Tuesday, August 25, 2020 1:41 PM
A little saliva on the plastic will help too.
