I use the Microset/Microsol combo regularly and it works really well for me. The most important thing to remember when you use the Microsol at the end is that you dab it onto the decal...and then DON'T MESS WITH THE DECAL. If you look at it while the Microsol is working, you'll see it start to get wrinkled and kinda nasty looking. That is normal, so its important to just leave it alone and let it work on its own. If you try to smooth out the wrinkles at this point, you'll destroy the decal. Just resist the temptation to mess with it, and it will smooth back out, all on its own. If necessary, once it has completely dried, you can put another application of the Microsol on it and repeat the process of just letting it do its thing. Repeated applications are sometimes necessary when you have a really irregular surface.
