Decal solutions staining clear coat and paint
    March 2021
Posted by Rob Hart on Wednesday, February 23, 2022 9:47 PM
Micro Sol left stains on the paint and clear coat (visible just adjacent to some of the stencil decals. Tamiya X22 clear coat over Tamiya Acrylic paints. Fundecal and Caracal decals. Not just dried residue from the water/solution. This is actually in the paint and won't wipe away. Had to be sanded down to the primer coat.Any guesses as to why?
    May 2004
Posted by cbaltrin on Wednesday, February 23, 2022 10:26 PM
This is normal. You have to be careful to wipe away the extra micro sol with a cotton swab or paper towel so there is no left lying on the paint. Some paints are more resistant than others, but as you found out, Tamiya is not one of them.
On the Bench: Too Much
    April 2020
Posted by Eaglecash867 on Thursday, February 24, 2022 6:54 AM
MRP paints don't need a clear coat prior to decals going on since nearly all of them are semi-gloss with a smooth finish.  They are also unaffected by decal solvents...even Solvaset doesn't stain or damage them.  But, short of revamping your entire paint inventory, MRP makes clear lacquers in 4 different sheens that are also unaffected by decal solvents.
Every decal on this F-16B went directly onto MRP paint and they all were given 3 applications of MicroSol, followed by another couple of applications of Solvaset.  No staining, and I just let the little bit of excess evaporate on its own.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
