Vinyl Decals
    June 2024
Vinyl Decals
Posted by Shlippyohboy on Friday, June 28, 2024 7:23 PM
Hello Les here. I am building an Itelari 1:6 scale Honda NSR 500. I am struggling with the peel and stick vinyl decals that came with the kit. They will not conform to the compond curves at all. I have tried using a hair dryer to heat then press them into place with very limited succes. If anyone has experience with these types of decals I would greatly appreciate your input. Thnx Les.
Posted by Tojo72 on Monday, July 1, 2024 3:35 PM
I wouldn't use them,sounds like they belong on a toy instead of a built model.
Posted by keavdog on Monday, July 1, 2024 8:13 PM
Check this out and maybe see if Italeri will send water slide decals to you
https://www.modelersite.net/viewShowRoom.php?id_contenido=2089
Thanks,
John
    June 2024
Posted by Shlippyohboy on Friday, July 26, 2024 9:53 PM
I hear you. but unfortunately thats what I got. There are no replacements out there. So basically I'm screwed. Cartograph should be ashamed of supplying such pour decals.
    March 2022
Posted by missileman2000 on Wednesday, July 31, 2024 7:33 AM
Shlippyohboy
If you have an inkjet printer and a scanner you can scan the vinyl sheet,  Then get some inkjet decal paper, and print the image on it.  Let dry for a few dayd.  Then coat wit a sealer, let that dry for a few days and you will have accurate water-slide decals.
