Academy decals
Academy decals
Posted by Anonymous on Tuesday, May 4, 2004 8:32 PM
Just finished building the F-86 sabre from academy . Applied future etc to model then applied decals . Man , they seemed to be made of leather ! Used micro set & sol , but still not conforming very well after the numerous sol applications ! Is this a common problem with academy decals , and if so , any tips on how to correct this ?
Thanks !
    December 2003
Posted by 9x19mm on Wednesday, May 5, 2004 12:59 AM
I have found their decals also to be problems it seems they dont like to bend at all even with setting solution(. Guess Ill just have to use after market decals with their kits no biggie though I still like their models even with this problem. Good luck to you.
Posted by Anonymous on Wednesday, May 5, 2004 2:10 AM
I just finished an old academy kit of an SR-71A Blackbird in 1/72. The kit itself was not too bad, some of the usual fit problems here & there, BUT... I really didn't have any problems with the decals. All of them had that creamy 'film' on the front & back. I dipped them in water for about 20 seconds, took them out, used a brush wet with water & brushed the 'junk' off the top. Dunked them back in the water real quick, and them let them sit long enough for me to get the MicroScale Decal Set applied. Then dabbed the edge of the decal to suck most of the water off. Slide it on, positioned it, & kind of pushed the water/decal set/air bubbles from under it out from around the center of the decal. Then applied the MicroScale Decal Sol. Of course it looked all creamy under the whole thing, but about 20-30 minutes later, it had applied & stuck on really nice. Of course I applied the Future first, two to three light coats. Then another coat of future after the decals to seal it. I saw Brett Green use warm water with a dab of dishwashing liquid to dip & loosen decals. That's what I've been using, along with the Future & MicroScale stuff & I've had no problems with any brand for that matter. If you can make sense of what I said, I hope that it may help.
Posted by rjkplasticmod on Wednesday, May 5, 2004 10:07 AM
Academy decals have always been a mixed bag. Sometimes they work fine, sometimes they don't. I usually just put em in the spares box & use Aftermarket decals.
    May 2004
Posted by albert_sy2 on Sunday, May 16, 2004 8:40 AM
Yes, Academy decals are pretty thick...
Groovy baby
