How to fade decals?
How to fade decals?
Posted by Anonymous on Sunday, May 9, 2004 9:15 AM
Hi All,
I'm building a Revell 1:48 F-14A Tomcat, (The jolly rogers USS Nimitz squadron) and I want to know how to give the decals that faded look. I'm going to weather the plane, and I want the decals to match.
Can I just leave them in the sun for a few days, and fade them naturally, or is there something I can paint on them?
Ta! Smile [:)]
    March 2004
Posted by uilleann on Sunday, May 9, 2004 10:12 AM
When I faded some of the decals on my F-117A I just sprayed a very light mist of the base color (black in my case) over them. They faded quite well I thought. I would assume that to achieve this effect on a grey or any lighter colored aircraft the effect should be pretty much the same. Just use a very thin mist of your base color and a pretty low pressure to spray it. Go slowly and check the flow of your airbrush often. If you get a run or a spatter you'll have to strip the decal off, re-finish the undercoat and re-decal again.
"I may not fly with the eagles.....but weasels don't get sucked into jet engines!"
Posted by Anonymous on Sunday, May 9, 2004 1:17 PM
Cheers, I'll look into that - i just ordered my first airbrush, so I'll have to practice lots first to get used to using it!
    December 2003
Posted by cbreeze on Sunday, May 9, 2004 7:59 PM
Greetings,
I just faded some decals on my 1/48 Tamiya Corsair. I read somewhere that one method is to rub the decal with an pencil eraser while it is still on the sheet then you cut and use your favorite application method. I tried this and it did give a good faded look to the decal. I did notice that the rubbing caused the decal to split while I was trying to apply it but it settled down real nice and you can't even tell that it tore. Maybe I rubbed too much. Anyway, this is just another technique I read here or on another forum.
Chuck
Posted by Anonymous on Monday, May 10, 2004 7:47 PM
In addition to spraying a light mist of paint over the decal as uilleann said above, i also gently sand the decals with about 1200 or finer grit sandpaper...it breaks the decals down and thins them here and there adding to the faded/worn look the paint misting gives them
Posted by Anonymous on Saturday, May 15, 2004 8:40 AM
Apply a coat or two of future over the decal and then airbrush a colour over it to give faded appearance. This way if you are not satisfied with result just wipe off the spray and try again.
Jack
