- Member since
Nuno, you are correct. The Future will degrade the NMF. If you can, trim the carrier film as close as possible to the graphic, apply the graphic & setting solution. May require more than one application of setting solution. With quality decals like AeroMaster, you should get good results. Test it in an inconspicous area to get the feel of what's needed to minimize carrier film visibility.
RICK
At My Age, I've Seen It All, Done It All, But I Don't Remember It All...
