Decals bubbled up!
Decals bubbled up!
Posted by Anonymous on Tuesday, August 3, 2004 9:44 AM
After a 25-year break from modeling, I’m now trying to establish a finishing system based on the current technology I’ve read about on various modeling sites. Working on a 1/72 A-10 kit, here’s what I did:
1 coat - Model Masters FS Enamel
3 coats – Future on decal areas (for gloss)
Apply decals using Model Masters Decal Set solution
24-hour delay
2 coats – Future (for sealing)
24-hour delay
1 coat - Model Masters Flat Lacquer (rattle can)
30-minute delay
2ndcoat - Model Masters Flat Lacquer
I didn’t notice any problem until I had the second flat coat on. I saw then that most (but not all) of my decals had immediately bubbled up in a nasty chemical reaction. Yikes! I’d thought I was nearly done with this project. I went to bed hoping for the best but today the decals still look horrible although, oddly, they’re sealed nicely around their edges.
What did I do wrong to bubble the decals like that? I thought that maybe water (insufficient drying time) was a probable cause but some of the large decals stayed okay while some of the tiny decals that should have been plenty dry bubbled up.
Also, I was disappointed that two coats of dullcoat still didn’t hide the glossy panels where the decals are. It looks like I’d need three or even four coats to blend everything. I can’t proceed with that though until I fix the above problem.
Any comments or suggestions from those present would be appreciated.
KTNR
Posted by MikeV on Tuesday, August 3, 2004 10:30 AM
I would give the paint 48 hours to dry and then spray the entire model with Future, not just the decal areas.
Wait another 48 hours and then decal it. After 48 more hours put another coat of Future over the decals to seal them. Wait another 48 hours and spray a coat of dullcoat on the entire model. Try and spray a light misting coat for the first two coats to seal the underlying Future and protect it from the lacquer in that Dullcoat. If you spray wet coats of Dullcoat over anything it is possoble to have it react with the underlying surface as lacquer is strong stuff.
