Aircraft Stencils?
    November 2003
Aircraft Stencils?
Posted by shrikes on Wednesday, August 4, 2004 3:49 AM
Just a question, guys... Do the aircraft stencils (you know, the tiny decals that say where access panels and the like are to be located) usually go over or under the national insignias?
I'm building a Philippine Air Force F-86D, most of which were aquired second hand from the USAF. If this were the case, do you think the PAF simply painted over the stencils, or would they take the trouble to put the stencils back?
Blackadder: This plan's as cunning as a fox that used to be Professor of cunning at Oxford University but has now moved on and is working with the U.N at the high commission of cunning planning
Posted by wibhi2 on Wednesday, August 4, 2004 9:22 AM
I would think the former instead of the latter.
3d modelling is an option a true mental excercise in frusrtation
Posted by berny13 on Saturday, August 14, 2004 2:47 PM
Before an aircraft is transfered to another country, it goes through a complete overhaul at depot. That country's markings are applied at that time and all stencils are painted on. Very seldom will there be a direct transfer. It would be safe to assume that the stencils would be applied over the national markings.
Berny
 Phormer Phantom Phixer
On the bench
