Decaling over bumps
    July 2004
Decaling over bumps
Posted by Albion on Monday, August 23, 2004 11:21 AM
I'm just in the process of decaling my first plane, the Tamiya Spitfire. I've put one of the targets on the wing, and it's smooth apart from a bit on the top of a protusion which has caused little creases to appear from it. The decal isn't flat against the bump either, the best way I can describe it is like a miniscule tent. Is there anything you can do about this sort of thing?
Darren
    January 2004
Posted by knight667 on Monday, August 23, 2004 4:35 PM
A setting solution, like MicroSet and MicroSol is a good way to go. MicroSol is best for getting decals to lay down over uneven surfaces. There's an article on it here somewhere...anyone?
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
Posted by darson on Tuesday, August 24, 2004 6:06 AM
Sign - Ditto [#ditto]Sign - Ditto [#ditto]
Darren (great name by the way)
I have use Microscale's Micro Set and Micro Sol for ages and they are great for settling down troublesome or thick decals.
Micro Set is a wetting agent that will allow you to move the decal around and place it where you want, while Micro Sol is a decal softener that will allow the decals to conform to compound curves and snuggle down into panel lines.
Cheers
Darren
Posted by Anonymous on Tuesday, August 24, 2004 9:22 AM
Cheers
Darren
'zactly..........and if i may.......once you've the decal in position and apply whatever quantitiy of MicroSOL.........L I A (Leave It Alone) while the sol solution does it's work........come back in a few hours or even the next day........and see what magic you've performed......
best 'o skill to ya.........
    July 2004
Posted by Albion on Wednesday, August 25, 2004 9:02 AM
Thanks all! Can I use MicroSol on decals that have already dried or is it too late for those?
Darren
    January 2004
Posted by knight667 on Wednesday, August 25, 2004 10:12 AM
Darren
Oooh, good question...I dunno. I know that I've "saved" decals before using my MM Decal Set after they've dried, but before top-coating them. Doesn't work that well, though, especially if the decal has cured over 24 hours.
But MicroSol is pretty potent stuff, it might work. Others might have more info...
Posted by Anonymous on Friday, August 27, 2004 2:12 AM
You can Sol a decal anytime.. no matter how long its been on a plane so go ahead.
Posted by MikeV on Friday, August 27, 2004 7:32 AM
Actually Solvaset is even better if the decals can handle it.
I have had it work with one or two applications where multiple applications of Micro Sol did not work.
Posted by Anonymous on Friday, August 27, 2004 1:08 PM
.........if the decals can handle it...........solvaset is some pretty potent stuff.......
railroadies use "Champ".......it's kinda between micro-sol & solvaset........
    July 2004
Posted by Albion on Saturday, August 28, 2004 6:28 AM
It seems I'm only going to be able to buy microsol online in the UK. Usual story. So I'm probably going to have to wait until I want to buy another model Disapprove [V]
Darren
Posted by MikeV on Saturday, August 28, 2004 9:45 AM
Rik,
I always hear people say that but I have yet to have any problems with it harming anything, but of course I have never used it on some of the better decals like TwoBobs. I used it on the Tamiya decal on the instrument panel of the P-47D I am building as well as the decals on the instrument panels inside the cockpit of my son's 1/72 Hasegawa Tornado he is building with no problems.
I also used it exclusively on my 1/72 Testors (Italeri) F-16 that I built years ago and it had no problems.
I wonder if it was less potent when I bought it and they changed the formula? Confused [%-)]
I have had this bottle for over 10 years.
    July 2004
Posted by Albion on Monday, August 30, 2004 11:06 AM
I managed to find a shop about 15 miles away that stocks micro sol so I managed to get my hands on some after all Cool [8D] It's a pretty useful shop actually, glad I found it.
Darren
