Decal Residue
Decal Residue
Posted by Anonymous on Monday, May 5, 2003 11:34 PM
I just applied some decals to a car. Some of the decals went on areas that are painted black. Now there is a white residue along the edge of the decal. The decal itself is clear. I tried wiping it off using water, but it didn't seem to come off. Can I get rid of this somehow?
Posted by midnightprowler on Tuesday, May 6, 2003 4:52 AM
Novus #2, or The Final Detail wax should work
Lee
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
Posted by Anonymous on Tuesday, May 6, 2003 1:15 PM
I looked at the decals again, and the white is under the decal. I don't know it there was a little air trapped under the edge, or if the decals dried a little cloudy over the black paint. I don't know how to fix this short of painting over the bad spots. Can I trim the edge off with a exacto knife? How would I remove the decal?
Posted by Anonymous on Thursday, June 5, 2003 9:42 PM
My solution to this problem is to apply some decal setting solution to the affected area and then GENTLY poke the decal with a new #11 blade. You can see the solution seep under the decal. Let it dry and it should be OK.
Posted by ponch on Friday, June 6, 2003 11:34 AM
If you haven't sealed the decal with future of dullcote or anything, solva set should be able to remove it without destroying it. You just need to soak it with a cotton swab for ten or fifteen minutes, afterwards you should be able to carefully slide it off to a side. Of course this doesn't work if you have already sealed it in.
