Advice regarding printing decals on inkjet printers
    October 2004
Posted by PC9_STRUCTENG on Wednesday, October 13, 2004 5:43 PM
Hello all,
Recently, I had my first attempt at printing custom made decals on a colour injet printer.
I used clear decal film produced for this specific purpose as I had to cope with a variety of backgrounds. Colours were marrone on white and lime green on a black carbon fibre texture. I sealed the printed decals with the usual decal film solutions.
I discovered that the printing was rather translucent once the decal had been applied. This caused me a real problem on the black background. I figure you can expect better results when printing onto white decal sheet, but of course for images with some detail, trimming that white away when you are applying the decal to surfaces which are other than white seems an impossible chore. I know ALPS printers could print white, but they are essentially like hens teeth these days.
Does anyone have any any advice/experience/etc on how to combat these sorts of problems. Any advice would be greatly appreciated.
Regards from down under,
Alfred
Alfred
(The Land of Oz)
Posted by gregbale on Thursday, October 14, 2004 8:29 AM
Alfred:
Printing on the white decal stock will definitely liven up your colors. The best I've been able to come up with to lessen the "close trimming" problem is to get in the habit of putting a border around your artwork before it's printed. Sometimes I use black, but usually I'll try to match the intended background color as closely as possible. I often (still) have to touch up the border with paint---before putting the decal on is easiest, but sometimes you'll also be left with a little white on the cut edge that needs to be touched up. If you're unsure of your steadiness of hand, a wider border may get this "touch up zone" farther away from the critical artwork.
Good luck.
Greg
Greg
George Lewis:
Posted by Anonymous on Friday, October 22, 2004 8:52 AM
Just do what some decal manufactures do to insure that you can't see through there decals on darker colour, which is give you two decals (or sometimes a white one to go under the main one). Print you markings twice then applied the second decal over the top after the first one has dried.
Posted by Lufbery on Friday, October 22, 2004 12:41 PM
Alfred,
I've had the same experience with decals I've printed recently (and also for the first time) with the Testors Decal System. I made woodgrain decals for the cockpit floor of a 1/74 scale biplane twin-engined bomber I'm working on. With the open cockpits, the floors are easily visible and I wanted them to look really good.
I realized pretty quickly that I needed some sort of light-colored background when I put my first decal down directly on the dark plastic of the kit. I quickly took the decal back off and resigned myself to the fact that there are no shortcuts with this kit.
I primed the pieces with enamel, then put down Testors MM Acryl radome tan. After that dried, I coated the pieces with Future. Having done all of that, the decals went down beautifully and responded well to Micro Set.
In my opinion, these decals need a light-colored background. One tip I read on a similar thread on this very topic is to print the decals onto clear plastic used for overheads and use them as masks. The idea is to cut out the decal leaving a hole in the plastic with the same outline. Then paint a light color background on the model in the shape of the decal. After that, just apply the decal on the background.
Regards,
-Drew
Build what you like; like what you build.
