F-117 decalling
F-117 decalling
Posted by Anonymous on Tuesday, October 26, 2004 12:06 AM
Hi all
I need some help with a nighthawk im doing(the Stealth Plane)
Because of Its flat black paint im not sure the decals will stick the the body
I need to know as i dont have acess to any microsolv and other decal products
Im stuck and dunno wat to do
Posted by Anonymous on Tuesday, October 26, 2004 5:20 AM
A couple things come to mind that may help you out here.
One is to put a clear gloss coat over the flat paint apply the decals. Then after they are dry put a coat of clear flat over the paint.
Another idea I have heard of but have not tried is. If you don't have access to microsol products is to try a water/ vinager mix. Something like 1 part vinager to 5 parts water.You may want to try this on a scrap model and decals before appling it to the plane.
Hope this helps
Paul
    October 2003
Posted by f-4phantom on Tuesday, October 26, 2004 4:39 PM
Decals should always be applied over a gloss finish. After decalling you can spray a clear flat finish.
Dean
Posted by Anonymous on Wednesday, October 27, 2004 2:28 AM
thanks guys i might try that vinagar mixture, see how it goes
