Decal Problem(s)
    January 2003
Decal Problem(s)
Posted by TEISE on Monday, May 12, 2003 1:58 PM
I've had several "slips" of decals from their prescribed positions.After the decal has dried in place is there a foolproof way to loosen it and move it back to the proper position.You only get one chance with decals.
TEise
Posted by Anonymous on Monday, May 12, 2003 3:24 PM
Try cutting small slits in the decal with a new blade. Coat decal with Microset and allow it to soak in. If that doesn't loosen the decal, go for broke and try Solva-set. To avoid re-occurence, always lightly blot the newly installed decal to get rid of excess water. Check your newly-installed decals about 30 minutes after you put them in place. Correct any slippages them, before the decal dries completely.
