help with decals
help with decals
Posted by Anonymous on Monday, May 12, 2003 8:09 PM
i put the decals on the hood of my project its painted with enamel decals are basic kit from revell and i had a little yellowish film around the clear part of the decal any ideas to not have this happen to fix the problem on the hood im gonna let it dry and carefully trim the decal to cut out the film any better ideas
    January 2003
Posted by leemitcheltree on Monday, May 12, 2003 9:45 PM
Deano,
Before you decal, tape the decal sheet to a window that gets a lot of sunlight (but not humidity) for a while - checking often - it might take a week or two - and the light will slowly fade the yellowing decal carrier. Then just use the decals.
Alternatively, use a new no.11 blade to carefully trim around the image, effectively detaching the decal from the clear carrier surround. Cut just deep enough to cut through the decal, not the paper, as it's easy to damage the decal. Then just dip the decals in water, and using your knife or some tweezers, remove the clear waste from around the decal and apply the image as normal.
Cheers,
Lee Tree
Cheers, LeeTree
Remember, Safety Fast!!!
Posted by midnightprowler on Tuesday, May 13, 2003 4:15 AM
You should always trim away as much of the clear carrier film from the decal as possible.
Lee
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
