Using Decals as masks
Posted by fiasco on Saturday, January 15, 2005 1:45 PM
Hi folks
Has anyone tried using decals as paint masks?
I'm building a 1/48 Bae Hawk in Red Arrows markings for the aerobatic GB and was wondering if I'll get a better result on the whites if I use the decals to mask over white paint whilst I spray on the red.
Anyone tried similar techniques? What are the pitfalls?
Cheers
Dave
Posted by Anonymous on Saturday, January 15, 2005 3:21 PM
Never done it but it sounds like an interesting theory. Just might give it t try.
Richard
    August 2004
Posted by Thehannaman2 on Saturday, January 15, 2005 3:44 PM
I've used dry transfers for letters and numbering with beautiful results. Decals as masking kinda scares me.
Justen
"The distance between genius and insanity is measured only by success."
Member IPMS Niagara Frontier. "The BuffCon Boys."
IPMSUSA Member 45680
Posted by rjkplasticmod on Saturday, January 15, 2005 7:24 PM
I've tried it with some success. Biggest problem may be the carrier film on the decal which makes the masked area larger than the graphic. Also, don't get a lot of paint build up on the decal or you may lift paint from areas you don't want to, when you remove the decal. The decal should not be applied with setting solutions, in fact best to get as much of the glue off the underside as possible. Scotch tape can be used to lift the decal after painting.
Regards, Rick
Posted by Anonymous on Sunday, January 16, 2005 1:23 AM
I've done ths with some success.
Scan the decal sheet, then print it on white paper.
take a piece of glass and stick down some masking tape, whatever you use.
cut out the decal off the white paper, leaving some overlap.
place it on the masking tape and use scotch tape to seal it in place.
Use an X-acto knife and cut your decal mask out, and carefully peel it off the glass.
the white paper decal may, or may not stick to the masking tape after you cut it out, but no matter.
The new cut mask on the lower tape is what you want.
Stick it in place and spray.
Posted by Anonymous on Wednesday, January 19, 2005 5:03 PM
Just finished experimenting with using dry transfers for masking. Worked like a charm, but you need to be careful when lifting with tape--like Rick said, gently is the best way. I also recommend some good Future surfacing under the dry transfers.
I would suspect waterslide decals would be similar (ofcourse, you'd not want to use the microsol type solvents and setting solution)only real difference is the carrier film may mask off more than you want--so you'll need to be extra picky when cutting out the decal.
Sean
Posted by fiasco on Thursday, January 20, 2005 8:03 AM
Cheers folks,
I'm going to give it a try, I'll let you know how I get on in the Aerobatic Teams GB
Dave
