White Fog
White Fog
Posted by kaimuki21 on Saturday, February 12, 2005 4:04 AM
Why do I sometimes get a foggy white film around my decals? It goes on clear with the Micro Sol and set and then dries white. It's not the decals but the area around them. Sometimes I can clean it with plain water other times it won't come off.
    January 2004
Posted by MusicCity on Saturday, February 12, 2005 11:15 AM
It's most likely one of two things:
1) Residue from the MicroSet / MicroSol. I had that happen once and thanks to a hint from someone here it came off easily with a Q-Tip moistened with MicroSol.
2) If you used either acrylic paint or an acrylic clear coat, either the MicroSet, MicroSol, or water is causing the acrylic to fog. I haven't had this happen (and I use acrylics almost exclusively) but I have heard of it. I've read that another light coat of clear acrylic will sometimes clean it up.
Posted by rjkplasticmod on Saturday, February 12, 2005 11:38 AM
It's called silvering. First, only apply decals over a smooth, gloss finish. If you still get it, then it's lack of good adhesive on the decals.
Regards, Rick
    January 2004
Posted by MusicCity on Saturday, February 12, 2005 7:11 PM
Rick, I don't think it's silvering. He said it's outside the decal and sometimes cleans off with plain water. Silvering would be underneath the decal.
Posted by rjkplasticmod on Saturday, February 12, 2005 7:42 PM
Scott, you may be correct, but I read it as possibly the carrier film outside the graphic. If it's the paint turning white, then he's probably using an acrylic that is reacting to the alcohol in the setting solution.
Regards, Rick
    January 2004
Posted by MusicCity on Sunday, February 13, 2005 7:28 AM
You could be right, Rick. Regardless, we've got both issues covered, I think Tongue [:P]
Posted by Swanny on Tuesday, February 15, 2005 5:44 AM
White fog is usually a reaction to the Future sealing coat. If you used Future before decaling just let everything dry then apply another coat of Future and it'll go away.
