That darn decal film......grrrr!! Any tips?
Posted by Anonymous on Wednesday, June 11, 2003 2:03 PM
Hi Everyone
Do any of you know a sure fire way to apply decals so when they dry you don't see the clear part of the decal (gets air underneath or something and has white areas)? The only way I know of is to paint on markings, or cut away the clear film but that is sometimes impossible with small or highly detailed markings. I've tried putting on a gloss laquer on the spot where I want to apply the decal. This helps, but doesn't completely solve the problem. Thanks for your help!
Posted by kaleu on Wednesday, June 11, 2003 2:25 PM
Try using a decal setting solution such as Micro-Sol and Micro-Set. I use both of these products and haven't had any problems with them.
Erik "Don't fruit the beer." Newest model buys: More than I care to think about. It's time for a support group.
Posted by Anonymous on Wednesday, June 11, 2003 2:42 PM
That effect is called silvering and I agree with you, It's very annoying. If you're granting a gloss surface before you apply your decals that should be enough, maybe you're wetting the decals too much and they could be loosing adhesive. I dip mines 10 secs, to allow the papaer get wet. Then wait 30 secs or more till the decal releases. And then slide out of the paper with a brush. If it's a complex surface a decal solvent solution it's really helpful.
Anyway, try this: dilute some future with water, maybe 1:1 ratio. Once you have applied the decal and it's in place apply this solution. If you want to remove silvering from already applied decals this tip will work too, use future undiluted and apply it to the border of the decal, it will go beneath it and fill the air space.
Posted by Anonymous on Wednesday, June 11, 2003 2:46 PM
start by putting down a clear gloss coat. use micro set/solvent. if the film still shows up a dull coat will help blend it in. if not.... rub some pastels on it. it will hide the film and make it look dirty.
Posted by djmodels1999 on Wednesday, June 11, 2003 3:04 PM
Try to apply them onto a fresh light coat of Future (apply the Future where the decal goes). Obviously, you'll need to re-varnish the whole model after...
Posted by Anonymous on Wednesday, June 11, 2003 3:35 PM
this is part of an article from the Tamiya website.
"After the DullCote dried, I sprayed layer of unthinned Future floor wax, by airbrush, straight onto the areas where the decals were be placed. This was a necessary step because of the thickness of the decals. The Future floor wax offers a clear built-up layer that the decal “sinks” into. Once the Future was dry, decals are applied in the normal manner and a small amount of Micro-Sol was placed over the top to ensure that the decal “snugs down” onto the surface of the model with no air bubbles trapped underneath. When the decals are dry, I check for silvering and spray another layer around the outside (carrier film) edge of the graphic. When this new layer was completely dry, I gently buff the future until there was no visible edge to the decal."
here is a link to the article
http://www.tamiyausa.com/product/plastic/tips/mmmgood.html
hope the can help you.
oh yah, personally i just try my best to cut away the excess, and that usually works. Have you tried looking into dry transfers??
Posted by Anonymous on Wednesday, June 11, 2003 7:40 PM
Tried and true Micro-Sol and Micro-Set.
