Hello Jeff
I use both the Testors Decal Maker program and Paint Shop Pro 9 which is now owned by Corel but a lot cheaper then the Corel suite or Adobe PhotoShop.
Paint Shop Pro 9 can be downloaded at www.corel.com . The cost to own is $119.00 to download but you can do a try before you buy.
Testors Decal Maker is created by the Sure Thing and you can look here for it www.decalgear.com/DG
I use a Cannon Scanner (CanoScan LiDE 30) and two different printers HP DeskJet 1120C Professional and a Epson Stylus CX6400.
The Epson Printer is one made for printing digital pictures and the ink is called DuraBrite which is made to withstand fading for up to 80 years.
I only use Testors paper both the white background and the transparent. I have tried others and found they do not work as well, I also use testors sealing spray a must have so the decals do not bleed when put into water.
I have do all my work in Paint Shop Pro now and print from it as well, I only use the Testor software now an again, it has some nice premade decals to steal and beatup in PSP.
HTH
Cheers
Thom
IPMS Member #42958 / AMPS Member #2091
IPMS Central Connecticut (President)
IPMS Northeast Military Modelers Association (Web Master)
Like Alice "I try to believe in three impossible things before breakfast"
