decals on tyres ?
    May 2005
decals on tyres ?
Posted by nick31 on Tuesday, May 31, 2005 6:35 AM
Will waterslide decals adhere to rubber tyres, the type used in Tamiyas motorbike kits ?
Anyone tried this already ?
    January 2005
Posted by jinithith2 on Tuesday, May 31, 2005 7:10 PM
just to be safe, I'd coat the decalling spot with future, and after the decal application, put future over it and over the future, a flat coat
Posted by Anonymous on Friday, June 24, 2005 4:07 PM
Doesn't Tamiya provide dry transfers for all of their tire decals?
    May 2005
Posted by nick31 on Thursday, June 30, 2005 10:28 AM
this is for a kitbashed bike with custom decals that I intend to print on waterslide paper.
    March 2004
Posted by DanCooper on Friday, July 1, 2005 1:52 PM
Waterslide paper... euh I thought that only came in white or transparent, tire printings are white, tires are almost black, how are you going to print that, since you can't print white with your home inkjet printer ?
On the bench : Revell's 1/125 RV Calypso
    May 2005
Posted by nick31 on Monday, July 4, 2005 5:11 AM
the plan is to print the decal on white paper using a black background. Then cut out as close to the text as possible.
Will probably take at least two decals - one over the other - for it to look white but I reckon its do-able. Used this technique to put whiote text on a black fairing and it worked fine. My only concerns are getting the decal to stick and the fiddly nature of the job.
Posted by Anonymous on Tuesday, July 5, 2005 7:32 AM
Decals don't stick to tires very well. You may have luck by coating the tires in future, but this isn't a surefire method. They may just end up falling off a couple days later.
