decal setting solutions
    July 2013
Posted by DURR on Wednesday, July 20, 2005 7:31 PM
anybody ever use white vinegar as a solvent
or alchol
    March 2004
Posted by bstrump on Wednesday, July 20, 2005 8:44 PM
To the best of my knowledge, most available setting solutions are based on these two liquids. The weaker ones use the vinegar and the stronger ones like Solvaset are alcohol based. I've never tried straight alcohol on decals but Solvaset is as close as you can get in setting solutions.
I assume you are trying to save a few bucks? Try diluting the alcohol and test it out to see what happens.
    May 2005
Posted by Bgrigg on Wednesday, July 20, 2005 10:02 PM
I would suggest using a vodka or gin, rather than whiskey so it doesn't tint the decals! Big Smile [:D]
So long folks!
Posted by Anonymous on Thursday, July 21, 2005 11:51 AM
Yes! and you can lick off the excess!
    March 2005
Posted by Aviator on Thursday, July 21, 2005 4:51 PM
But be careful; in the process of licking the excess, you may ruin the decal.Big Smile [:D]
Posted by Anonymous on Friday, July 22, 2005 2:21 PM
I had an old model that I was trying to remove the decals from, and I used isopropyl alcohol straight from the bottle. After a bit of a soak, the decals shrivelled up quite a bit. If you're going to try alcohol, I would recommend diluting it first, though I don't know by how much.
