"dulling" decals
"dulling" decals
Posted by Anonymous on Tuesday, August 16, 2005 10:06 PM
I have no problem putting on glosscoat before I adhere decals, but after I put on dullcoat there is still a slight sheen that makes the model look a Toys r Us peice of junk. any tips would be appreciated.
    September 2004
Posted by Borg R3-MC0 on Wednesday, August 17, 2005 3:15 AM
This is my sequence for decals:
1) gloss coat
2) put on the decals, using vinegar and/or setting solution
3) second gloss coat, (seals decals from the wash)
4) dullcoat
    January 2004
Posted by MusicCity on Wednesday, August 17, 2005 9:38 AM
I agree with that sequence, it's what I use. However, there should be a "Wash" step between items 3 and 4. If you omit the wash there is no need for the gloss coat over the decals and before the dull coat.
Also, are you putting gloss only where the decals go or are you doing the entire model? If you put it only where the decals go then you have two different finishes for the flat coat to try and cover.
Posted by Anonymous on Wednesday, August 17, 2005 3:26 PM
Thanks , it's clearer now
