Blank Decal Sheets
    November 2015
Blank Decal Sheets
Posted by Ranger_Chris61 on Saturday, August 20, 2005 11:52 PM
Where can i find some blank decal sheets to make custom decals with?
    March 2004
Posted by Mark Joyce on Sunday, August 21, 2005 9:19 AM
I got mine at Micromark:
http://www.ares-server.com/Ares/Ares.asp?MerchantID=RET01229&Action=Catalog&Type=Department&ID=106
Mark
Ignorance is bliss
    June 2004
Posted by clfesmire on Sunday, August 21, 2005 10:32 AM
I have had good luck with the decals film from BMF that can be used with an ink jet printer
http://www.bare-metal.com/
Posted by grandadjohn on Sunday, August 21, 2005 2:57 PM
Testor's makes some also.
Who makes 8x10 or 8 1/2x11 sheets for inkjet printers, hopefully someone I can find locally? Would rather not mail order
    February 2005
Posted by RadMax8 on Monday, August 22, 2005 11:55 AM
John, check out your LHS or walmart. I've heard of Wally world carrying Testors paper
    July 2003
Posted by schulerwb24 on Monday, August 22, 2005 12:16 PM
Hobby Lobby carries both clear and white Testor's decal sheets, 5 or so to a packet. Also the clear spray to seal the decal after it is made, which smell, looks, and acts like Krylon Crystal Clear. I use the Krylon, it's cheaper. Kryon can also be purchased at Hobby Lobby .
Testors come in half sheets, which work good in that you are not wasting a lot of decal paper if you only have a few decals to do. I have tried several other decal papers for inkjet printers and I think the Testors has the edge over the others.
Posted by Anonymous on Sunday, September 18, 2005 1:43 PM
I need advise on this. I am new at doing plastic aircraft models and need to know where I can get sheets of water slide decal paper that will allow me to strip off 1/16th inch strips to place on the wing tops and fuselage. Any help out there? Richard
    May 2003
Posted by qmiester on Sunday, September 18, 2005 6:58 PM
Most of the decal manufactures can supply you with solid sheets of the most common colors. Just slice them the width and length you need and apply. I always try to keep a sheet of clear, red, white and black on hands at all times. Check out Roll Models or Squadron or most other on line suppliers.
Quincy
Posted by tyamada on Monday, October 31, 2005 6:33 PM
Here is a place to get blank decal stock at a reasonable price.
http://www.beldecal.com/
