bsg viper: battle damaging decals
Posted by Anonymous on Sunday, August 28, 2005 6:31 PM
I tried to mask and paint the stripes on my Revell Viper, because I wanted it to look painted on, first off, and secondly so I could scrape some off and have it look like wear/tear...but it just looks awful. The paint bled under the masking tape, the paint was too gummy and now all the brush strokes are showing, it looks like dook.
So now I'm resigned to giving the decals a shot. I'm not looking forward to it; I still have decal nightmares from my childhood.
So, does anyone have a good technique for creating wear on decals? Paint over them with the base color? tear them?
    November 2003
Posted by roosterfish on Monday, August 29, 2005 2:19 AM
I assume you are using an airbrush? If you are then you got it. It takes a lot of patience to get the right look of wear on decals. A little base color spray, scraping, base color, wear spots get colors. You have to layer colors and alternate scraping the decal. Go lightly when spraying base color over the decals because you'll probably have to spray a couple of layers of fine paint that will build up. Don't get scared but dig in and have fun. The ship is suppose to look worn with scuff marks.
Click on my "Connie" down below and you'll see the different layers of colors, scrapes and damage to the ship.
Winners never quit; quitters never win.
Posted by Anonymous on Monday, August 29, 2005 6:57 AM
I wish I WERE using an air brush...then perhaps I could have just used a mask and got the stripe painted without all the gross brush strokes.
I'm trying to get one pretty soon though, so I'll take a look at your suggestions. Thanks!
    August 2005
Posted by eizzle on Monday, August 29, 2005 9:14 AM
if you are trying to prevent the tape from letting the paint bleed underneath it, spray a light coat of clear on first, that will seal the tape and if some clear goes under the tape, its clear, so no worries.
Colin
 Homer Simpson for president!!!
Posted by Anonymous on Sunday, September 18, 2005 9:41 PM
Maskol works better than any tape, for canopies, camoflage, everything
Posted by waikong on Monday, September 19, 2005 11:42 AM
Its hard to prevent bleed thru with brush painting - the clear coat first will help. Since its stripes, I would suggest getting a spraycan, warm it in warm water first, shake it up well, start spraying before the model and stop spraying after pass in the model in a stroke. Go fast and try not to cover in one pass - always keep moving. You can always make 2nd, 3rd, etc. passes. But you can't take away too much paint..
As for decals, yes you take your base coat color and paint over the decal. That works.
