Decals on curved surfaces
Posted by Anonymous on Monday, September 26, 2005 10:37 PM
Working on a Revell P51 with pretty complex decals at the cowel and engine cover, a checkerboard pattern. I got the decals on okay, but I am having trouble getting them to conform to the curve of the model. They have a pattern to cut the decals to make them fit, but it didn't work too well.
Any ideas?
Later,
Zappa1
Posted by Anonymous on Tuesday, September 27, 2005 1:35 AM
Ey Zappa, have you tried decal setting agents like Micro Sol or Mr.Hobby Mark Softer? if you havent tried them before you'll be amazed by the results.. it'll really conform to whatever curved sufaces you might have. just place the decal on with water, dry it up a bit with kleenex,then gently apply the solution with the brush supplied with the bottle..(like cement) then watch as it gently conforms to the surface.some decals might react to the solution.(i found Mr.Mark softer to be less reactive when it comes to most decals.) some decals might even warp when used with it,don't be alarmed though because it'll straighten itself out when dried. i personally have tried both setting agents and use them when fit for the decals. try some on the extra decals on the sheet first. Hope this helps! Happy modelling!
    May 2005
Posted by IceDragon122 on Saturday, October 1, 2005 1:23 AM
QUOTE: Ey Zappa, have you tried decal setting agents like Micro Sol or Mr.Hobby Mark Softer? if you havent tried them before you'll be amazed by the results.. it'll really conform to whatever curved sufaces you might have. just place the decal on with water, dry it up a bit with kleenex,then gently apply the solution with the brush supplied with the bottle..(like cement) then watch as it gently conforms to the surface.some decals might react to the solution.(i found Mr.Mark softer to be less reactive when it comes to most decals.) some decals might even warp when used with it,don't be alarmed though because it'll straighten itself out when dried. i personally have tried both setting agents and use them when fit for the decals. try some on the extra decals on the sheet first. Hope this helps! Happy modelling!
Totaly agree.........working on a B-17G 1/48 scale by Revell and wow....Solvaset....or MicroSol (I use solvaset) works fantastic!
-Brian
Posted by Anonymous on Sunday, October 2, 2005 10:29 PM
I tried a couple of things. Someone on one of the boards suggested vinegar, but I didn't get very good results. Next, I put some leftover decals on an old Camaro model, and then brushed them with straight Toluene. That actually worked pretty good. Lastly, tried straight MEK on the same decal. I do not recommend that, even though it did have a pretty neat smearing, running effect. I'll play around with that some more to see how it may be of use on some other projects. I had the best results with the Toluene. Does anyone know where I may be able to get an MSDS on MicroSol. That stuff can't be that hard to make can it?
Later,
Zappa1
    September 2003
Posted by stindle on Monday, October 3, 2005 4:40 PM
Later,
Zappa1
I would say to put the MEK down and walk away from that stuff. Its pretty nasty stuff. We used to use it to clean the Kit housings on c-130 engines when I was in the air force. Stuff will cut right thru grease np and it will soak right into your skin too.
Skip
Posted by Anonymous on Monday, October 3, 2005 10:36 PM
Oh, don't worry about me and the MEK. I stay away from that stuff when I don't need it. I usually only use it for cleaning tough stuff. Just thought I'd give it a shot to see what it'd do.
