Cracked decals
Cracked decals
Posted by Anonymous on Monday, October 3, 2005 11:50 PM
Is there anyway to save the remaining decals. I've tried to applyed one on my RM 1/32 Typhoon but it shattered when taking it off. I think I can replace it but would like to salvage the rest, any ideas???
    July 2003
Posted by schulerwb24 on Tuesday, October 4, 2005 12:07 PM
Well, first I would make a good color copy of what is left. That is so if what you try does not work, you have a copy to make your own decals with a color copier or printer. Then, get some Microscale Decal Film, cover one or two of the images with a couple of coats. One coat should be sufficient, but if they disentegrate, put two coats on. Let dry over night. Cut out, soak and remove the decal as usual, be very careful with it, handle as little as possible, see if it stays together. If so, coat the rest of the decals and go for it. If that does not work, try spraying a section of the sheet with several light coats of Krylon clear spray. Again, try the decal, if it works, spray rest of sheet with Krylon. If neither of these work, unless someone else has a good suggestion, go with "Plan C" and make some decals from your copied decal sheet.
Usually, Micro Decal Film will fix the problem, I use it most of the time to fix old, disentegrating, decals. Krylon works good too, good for large sheets that need fixing. But, sometimes, they are too far gone and you have to make your own.
    May 2003
Posted by qmiester on Tuesday, October 4, 2005 8:50 PM
MicroScale makes a liquid Decal Film which works fairly well to salvage old brittle decals. Just paint on two or three coats and when dry, trim your decal as close as possible to the edges and apply. Another thing which should work for you is to spray on a coat of Gloss coat over the decal.
Quincy
