Decaling on Bare Metal Foil
Posted by Anonymous on Wednesday, October 5, 2005 3:22 PM
I'm about to apply decals to a surface that is Bare Metal Foil. I want to make sure that I don't mess up the metal finish. Is there any sort of prep work I should do (or shouldn't do) before hand? Is it safe to overcoat with Future over the whole model, or should I just apply it to the decals themselves?
Posted by Anonymous on Thursday, October 6, 2005 11:48 AM
jtruban,
After foiling, I used steel wool (which reduces the shine and roughens the surface a bit) as described here:
http://finescale.com/fsm/default.aspx?c=a&id=283
Then Future over the whole model, then decals, then Future over the whole model. No issues with this procedure.
Best of luck,
Andre
Posted by Anonymous on Friday, October 7, 2005 6:51 AM
I've never had a problem decaling over foil. Just make sure you trim them close to the design so the clear carried does not show against the foil.
