I, too, have had the problem with inkjet printings in yellow and also light gray disappearing into the background, especially if it is a blue or OD. Multiple layers did not work. Agree with woodbeck3, use white and cut carefully. However, if using Word, you can set up a box around the yellow printing, send to the back so the text is in front, adjust the box color to match your background paint, and print. Cut close to the printing, install decal, touch up with the background color. This has worked several times for me. However, getting the box color to match can be a bear and will take several attempts to get it right or close. There was a web site I ran across that had color matches for microsoft colors to many FS and other colors, but do not have it at my fingertips right now. Am just starting to try their color matches so can not say if it is good or not. Oh yeah, use white decal paper for this procedure so the yellow has the white background to lay on.
