File type for decal scans
Posted by R Bolton on Thursday, March 2, 2006 2:46 PM
Hi,
What file type is the best for printing decal sheets from scans?
    January 2003
Posted by Jeff Herne on Thursday, March 2, 2006 4:34 PM
If you have the ability, hi-res TIFFs are probably your best bet, since you can adjust the color data without much degradation.
JPGs tend to deteriorate with multiple cuts, pastes, and copies, but for decal printing, a hi-res JPG will probably suit your needs just fine.
Jeff
    May 2005
Posted by Bgrigg on Thursday, March 2, 2006 4:50 PM
Jeff
Not to mention oddball compression artifacts that show up for no apparent reason!
JPG = Just a Piece of Garbage!
So long folks!
Posted by Anonymous on Thursday, March 2, 2006 11:43 PM
Dear Sir,
          I don't use raster based formats for printing decals at all, Get yourself a good drawing program and scan to one layer and do your trace drawing on another layer, after you are done, just delete the scan layer, this way if you have to resize, the graphics are in vector format with no loss or clean up of the edges to do. Stenciling and any text you can change to path object and resize to the smallest of size, I have text for 1/350th scale aircraft that I have done in this fashion.
Barney Kable
bhkable@earthlink.net
Posted by Anonymous on Friday, March 3, 2006 10:51 AM
I too, have used Illustrator eps files for making decals (unit numbers and insignia) for my Canadian HO scale (1/87) modern military vehicles. The resizing is what I wanted. Just like Barney said...no loss or cleaning up needed.
