Fujimi decals glued to cover sheet!?!!
    January 2006
Posted by pinkboy on Monday, March 6, 2006 11:23 AM
hi folks.  I'm working on a Fujimi 1/72 Japanese Gekko "Irving", and the decal sheet was sealed in its own plastic bag, with a cover sheet over the surface.  Good intentions...but the cover sheet was GLUED to the front of the decals!  I tore it off, but it left a horrible mess of cover-sheet-fibers all over the decals!  The decal sheet is ruined if I can't find a way to wash off the fibrous mess!  I've tried warm water, detergent water, acrylic thinner, and enamel thinner.  Nothing works.  In trying all this stuff, I did get one tiny decal to shed its crud, but that was just random chance.
Does anyone know something that might work to clean the fronts of these decals?  I can substitute other decals I have...but it's the principle of the thing, plus I'd like to know the magic substance if there is one.  Thanks.
george
    June 2005
Posted by archangel571 on Wednesday, March 22, 2006 12:50 AM
subscribing to this.  i have the same problem with a matchbox lancaster.
-=Ryan=- Too many kits... so little free time. MadDocWorks
    October 2004
Posted by ikar01 on Saturday, April 1, 2006 8:36 PM
I had someting similar happen to a set of WWI decals that was putting on a spad.  To take a chance I put the decals in water and after a couple minutes I used a wet Q-tip to carefully scrub away the paper on top of the decals.  Except for a small piece here and there I got the paper off.  I did have one advantage, the decals were designed to fit over large sections of the aircraft so I had some room to work with.
    January 2006
Posted by pinkboy on Wednesday, April 12, 2006 9:35 AM
Thanks, ikar01.  I've got nothing to lose, so I'll give it a try.
george choksy
