layering decals
    May 2005
layering decals
Posted by nick31 on Wednesday, March 15, 2006 4:21 AM
Im applying a white decal on a dark surface. The problem is the dark colour is showing thru the decal, so I'll need to apply two or possibly more layers of decals to make them appear white.
As far as I see it, theres 2 options:
1) when first decal is dry, just apply the second decal on top. Doesnt adhere well, and may possibly move when applying gloss coat
2) when first decal dry, give it a coat of future, when dry apply second decal.
2nd option seems obvious choice. anyone agree or got a better idea ?
    January 2003
Posted by Triarius on Wednesday, March 15, 2006 9:55 AM
Second option sounds easier.
Have you considered using the decal as a pattern for a mask? Friskett matt film works well for this. Then you can mask off the area and apply a white undercoat to the decal—or just use the mask and paint the area. If you do that, consider painting the white area silver, first, as that will give better hide and reflectance to the white—cuts down on the number of white coats you have to apply.
    May 2005
Posted by nick31 on Thursday, March 16, 2006 3:42 AM
interesting, but the decals are quite small numbers and itd be a nightmare trying to mask the shape of them.
will try option 2 above and see how it goes.
    March 2005
Posted by mfsob on Thursday, March 16, 2006 9:25 AM
I tried the same thing, making custom yellow serial numbers for my Doolittle Raid B-25B; found the right font on the web and everything, but no matter what I did, I could not get the yellow "solid" enough to keep it from going translucent. I layered very light gray and then black underneath, allowed that to thoroughly dry and then put the yellow decals on top with just some setting solution, there didn't seem to be a problem with the first layer wrinkling or bunching - but the yellow still faded to almost nothing.
I had to give up and buy aftermarket numbers that were not the correct "steciled" style but by that point I was sick of the whole attempt.
    May 2005
Posted by nick31 on Thursday, April 6, 2006 11:37 AM
well, just to let you know, I tried option 2 above and it worked great.
The coat of future over the first decal gave a great "grip" for the second decal, and its now pure white with none of the background color coming thru.
Wel pleased with the result.
