modpsych wrote: |
Hey T
Just a short one this time. Should I do the whole model in Gloss first, put on the decals and then a coat of either gloss or flat or just put gloss on where the decals go? .
Thanks
Gary
Depends...
I generally use an acrylic for a "top coat" after painting with a flat enamel "undercoat" since it dries hard faster, sealing the enamel's surface from fingerprints, etc., especially since usually acrylics tend to be a bit thinner, and can let the color they are painted over "bleed through" more then enamels, and require more coats with no enamel color undercoat. Also, they tend to "chip off" easier, and the enamel underneath helps to make it easier to "touch up".This is especially true with light yellows and whites, and in these cases the acrylic is frequently a gloss anyway.
To keep special weathering paints you may have applied, from getting prints, smears, etc. you may want to coat the entire model with either a gloss or flat acrylic clear to seal it before decalling.
The main disadvantage is that the dull/flat coats tend to "lighten up" any color some since they have a white powder in them for the dull finish, so too may coats of the dull stuff can definately give you a "funny shade" you may not want.
If there are complete large surface areas where there are not markings, I normally apply the desired dull coat I want to those areas, and apply gloss to the sections only where the decal markings are to go, apply the decal(s) with some setting solvent if needed, and let it throughly dry, and then finish dull-coating the decalled areas.
I hope this gives you some options to work with
Tom T
Tom T
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
