So it was going fine until......
jwb
    February 2006
Posted by jwb on Wednesday, April 19, 2006 8:27 PM
I was finishing up my Hurricane IIc. I'd painted everything to my liking, and I added the decals, dipped 'em in water, placed them, used a Qtip to push out the air bubbles, etc. Everything looked good. Set it aside for a few days.
I then added a coat of future, and let that set for 2 days. I added some wash to the panel lines, and after that was complete and dry, I put down a layer of dull coat from a rattle can.
I went out to check on the progress of drying- and the decals were blistered up. I tried to smooth them down, but the dull coat was still slick, which seemed to make a worse mess.
Two questions-
Any ideas on what I did to cause it? I thought the Future would seal it up- maybe another coat should've been applied?
Any ideas on how to correct it?
Thanks....
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
Posted by Anonymous on Wednesday, April 19, 2006 9:16 PM
i've had that happen with the rattle cans before,are you sure that you didn't put it on a little heavy?
i found that to be the cause for my blistering,now i kep a hair dryer with low heat on the ready and as soon as i spray the dull coat i wait about 30 seconds and then blow dry it,i haven't had that problem since.
also remember that depending on your geographic area the weather is warmer and the humidity is on the rise which can have an effect on how it dries and how long the laquer has to eveporate
    May 2005
Posted by Bgrigg on Wednesday, April 19, 2006 11:49 PM
I'm going to blame the rattle can as well. They can damage a two day old Future coat no problem. You may have to wait a week or longer for Future to "cure" all the way. Or you can add Tamiya Flat Base to Future and spray away. Check out Swanny's complete Future thread in the Techniques forum for hints on the proper ratios for satin and dull coats. And experiment! A little Flat Base goes a long way, and it's much harder to gloss up a flat than it is to flatten out a gloss!
So long folks!
jwb
    February 2006
Posted by jwb on Thursday, April 20, 2006 5:34 AM
Thanks y'all. I'll do some more reading and 'sperimenting. I may have sprayed it on a little thick, especially on the one wing where there was the most blistering.
I was pleasently surprised- I checked it this morning, and much of the blistering had settled down. It's still noticable, but it's gone from "throw it in the trash" to "just ook at it from a distance". :-)
That's what I like about this forum- good answers!
Jon Bius
    February 2006
Posted by Wulf on Thursday, April 20, 2006 7:23 AM
Some FYI jwb, rattlecan coats will also wrinkle the paint job if too much is applied. I found the best way to avoid this is to use acryl clear coats as opposed to enamel/laquer coats.
jwb
    February 2006
Posted by jwb on Thursday, April 20, 2006 8:05 AM
I'll give that a shot too. I worried about the enamel coat. It smelled so strong I figured it had to be some powerful stuff.
Jon Bius
    July 2004
Posted by tho9900 on Saturday, April 22, 2006 6:27 AM
I'm also a convert to acrylic clear coats... the Polly Scale (Floquil) and Aircraft colors clear flats are much flatter than the Testors dullcoat and they give a more uniform flatness as well!  (plus they don't have a smell, unlike the Testors...  Yuck [yuck])
