Help w/ Testor's Decal Sheets
Posted by kielers on Friday, April 21, 2006 3:18 AM
I need to make a couple decals for the Avenger I'm building.  I have a pack of Testor's decal film for inkjet printers.  But, according to the instructions I need to apply a spray-on bonding agent after the decals are printed and dry.  It says this is to bond the ink so that the decals won't separate when removing from the backing and applying to the model.  I don't have the bonding agent.
So, my question is; is there something else I can use for a bonding agent like enamel clear flat, or acrylic clear flat, or maybe even some Future sprayed on?  It seems to me that if the ink is enamel or something similar then the enamel clear coat should work as a bonding agent.
I appreciate any help or insight any of you can give me.  Thanks.
Steven
"To stand upon ramparts and die for our principles is heroic, but to sally forth to battle and win for our principles is something more than heroic." -- Franklin Delano Roosevelt. "Never in the field of human conflict was so much owed by so many to so few." -- Winston Churchill
Posted by Anonymous on Friday, April 21, 2006 9:10 PM
i've used the regulay Testors flat coat and gloss coat from the spray can,they smell the same as the bonding agent,also the wal mart here sells the bonding agent with the rest of thier spray cans,it has a blue label and is product # 9200
