gloss or semi gloss?
    April 2004
Posted by BigDuke634 on Wednesday, May 10, 2006 9:03 AM
Do you think it's better to put a gloss coat to the kit, then decal? Or can i use a semi gloss?   Ive done it before with a gloss coat ,  added the decals , waited a few days then added a gloss coat on top of that, and all the decals crinkled!!    Where did I go wrong?    Any advice would be greatly appreciated.
Posted by Reddog on Wednesday, May 10, 2006 10:05 AM
Put a gloss coat on before you decal, it will help stop the decal from "silvering". If you use a semi-gloss coat then you will still get air bubbles under your decals and will cause the dreed "silvering" effect.
As far as the decals crinkling, it depends on what you are using for your gloss coat. A great thing to use for a gloss coat is Future Floor Wax. You have find it in any grocery store or other stores that sell house hold cleaning products. You can either brush it on or spray it and you don't have to thin it when you do spray it. I highly recommend using the Future, I have used it for over ten years and have never had a problem with it.
"Any problem can be solved with a suitable application of high explosives."
    January 2003
Posted by Triarius on Wednesday, May 10, 2006 11:40 AM
It sounds like the decals were poorly bonded to the gloss coat underneath. When the gloss coat on top cured, it shrank (all coatings shrink, at least a little, when they cure). The shrinkage caused the decal to debond and crinkle.
Not all gloss coats are created equal. I, too, recommend Future as the "safest" for the decals, underlying, and overlying paints.
