Thanks guys. The light mist coat did the trick to protect the decals before following up with a heavier coat. No more dissolved decals. But now I'm chasing an orange peel problem with this Minolta 88CV kit I'm working on.
http://images15.fotki.com/v337/photos/7/730934/3837267/_MG_5571-vi.jpg
The paint is Tamiya Acrylic applied with an airbrush. The clear coat is Krylon Triple-Thick Cyrstal Clear Glaze 0500 (recommended by a Model Maker at work). The first coat was rough, of course, because it was so thin. I laid the second coat on a little thicker, and ended up with major orange peel and even plenty of rough spots. The above picture is after the third coat. I laid it on fairly thick and the orange peel started out even worse than the above picture, before settling into that form.
I'm painting in an air-conditioned room (spare bathroom, with a vent). Is it too cool in the room? (Around 75F) I've heard of heating the part with a hair dryer before applying the clear. Can anyone recommend that method?
Is there a good clear coat I can apply with an airbrush that won't dissolve water-solvent decals?
Thanks in advance.
