why after varnishing, the decal shrink ?
Posted by Anonymous on Thursday, July 6, 2006 11:39 PM
how to remove the decal ?
thank You
    April 2005
Posted by T_Terrific on Friday, July 7, 2006 11:02 AM
In order to answer your question, it would help to know:
  1. What is the subject decaled-make and type of model.
  2. Did the decals come with the kit?
  3. What did you use for varnish?
Due to their alcohol base, some clear acrylic coats can literally melt a nice decal if applied too heavily.
  Tom T Cowboy [C):-)]
Tom TCowboy
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
Posted by Anonymous on Sunday, July 9, 2006 9:46 PM
Tamiya Ferrari F-1 2002, the decal come with the kit. Tamiya Clear TS-13(if i'm not mistaking)
    April 2005
Posted by T_Terrific on Monday, July 10, 2006 9:49 AM
Yes, your Tamiya TS-13 is a spray lacquer, which has a very strong solvent that can even remove fingernail polish!
If you go to this link to the decalling forum, you can get a lot of helpful info:
http://www.finescale.com/FSM/CS/forums/641519/ShowPost.aspx
Many, if not most of the fellas here use a mixture of Future floor polish and other stuff. If you want more info about using that, you can just enter "Future" into the search block below,and start reading the references to mixing the floor polish product for models.
I definately would not recommend "going there again" in using a Tamiya spray lacquer over any decals, as even as I mentioned before a havey coat of a high alcohol ratio clear acrylic will literaly melt them also.
As for your decals, I would say they are "goners" and seek to remove them using lacquer thinner and a bit of scraping with a dull knife, sand the surface, touch up the paint, and seek to use some others.
Good luck
Tom TCowboy
