Archer techniques
    January 2003
Archer techniques
Posted by dogzilla17 on Friday, September 8, 2006 8:30 AM
I'm having a bit of an issue w/ applying Archer balkenkreuzen on my almost done dragon Panther D -- I applied Future and commenced the 'wet' technique ie rubbing the decal onto blank decal film, then soaking and sliding into place-- I used microsol , but the decal seemed a bit tacky before it was properly positioned, so wasn't easy to move into place-- any suggestions or tricks?   I've got turret numbers going on next-- has anyone used microset w/ archer?
Thanks --
Dog
    May 2003
Posted by DrewH on Saturday, September 9, 2006 10:16 AM
Sign - Oops [#oops] That's the easiest way to put it. Once you put the transfer onto clear decal stock, you need to "coat" it with Microscale's liquid decal film or a clear enamel to seal the transfer on and help protect it. Did you let the future dry first? After that, you should use micro set on the model. This is a cleaner that prepares the model and decal. Once the decal is positioned and has had the excess water and microset dried up, then you apply the Micro sol. It softens the decal, hence why it got sticky. It let's the decal settle onto the model and get over and into any details that are there. HTH
Drew
Take this plastic and model it!
