applying decals, a query !!!!
    May 2006
Posted by ian lanc on Saturday, September 30, 2006 4:35 PM
Hya all, i.ve bought a 'sanger' 1/48 vac form avro lincoln,   on the instructions about putting the decals on model it says YOU MUST USE WATER OR ACRYLIC BASED LACQUER TO VARNISH, NOT POLYURETHANE OR ENAMEL LACQUERS !!! over the decals, does anybody know why you can't use enamel paints [will it attack decals] and what are the above lacquers like to put on model, never used any water based paints at all............ any replies welcome  ....... ian.  Confused [%-)]
just doing one more model ! thats all.
    March 2006
Posted by Dubau on Sunday, October 1, 2006 8:43 AM
Never hurd of that. The only thing I think you need to do is have a gloss coat on before you put your decals on.
If you painted it flat just out on a clear gloss coat and then your decals and another flat coat it that's what you need.
Here check this out. I have it and it works GREAT !
http://www.ares-server.com/Ares/Ares.asp?MerchantID=RET01229&Action=Catalog&Type=Product&ID=82400
Hope that helps
Bud
" You've experienced a set back, and without set backs and learning how to fix them you'll never make the leap from kit builder to modeler "
