Airfix 1/72 Aichi Val
    January 2007
Posted by Intruder38 on Wednesday, January 24, 2007 8:39 PM
After a long (15 years) lay-off from plastics, I am inching my way back in with the Airfix kit (I am half way through an RC version). My 20-year old decals are a bit the worse for wear, although if the sun will bleach out the yellowing, they may still be usable. That being said, I would like to cover my six with a fresh set of decals for the Val or, at least, suitably sized hinomarus. I have visited every model supply site I can think of and cannot find any Japanese markings listed. Can anyone point an old codger on the right direction (slowly, of course)? Thanks for any help you can provide.
    April 2005
Posted by T_Terrific on Monday, February 12, 2007 1:28 PM
I know this is not the answer you are looking for, but I recommend you just go out and buy the 1/46th scale Revell kit if the Val is your favorite subject.
Tom Cowboy [C):-)]
Tom TCowboy
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
    January 2007
Posted by Intruder38 on Monday, February 12, 2007 5:54 PM
Tom,
I chose the Val to re-enter the world of plastics because I have an RC 1/9th version half built and thought it would be a good way to get ideas for detailing the big bird. My collection of kits, built and unbuilt, is pretty much all 1/72nd scale because of display space limitations. And with all the stumble thumbs I am having with this kit, the smaller the better; that way I can say with a straight face that I'm only making little mistakes.
    April 2005
Posted by T_Terrific on Tuesday, February 13, 2007 8:52 AM
I understand, I went throught that too when I re-entered scale plastic models. It can seem intimidating, but honestly, since getting "up there" myself, I find the 1/72 stuff much more tedeous then the 1/48th and larger.
You see, when we were younger, along with our bodies, which included sharper eyesight, our hands and fingers were smaller and so the 1/72 things didn't seem so bad.
I do think if you have a favorite subject, it is good to do a 1/72 kit first, just to get the feel, but you will find on the 1/48th and larger, it is easier to do fine details and fixes without messing them up, since everything is bigger, hence not so critically tiny.
On the other hand, I would start by taping the decals to a south-facing window pane to bleach them if you want (I never do, since the worst I have seen is white going to a slightly dirty off-white, which is more like field conditions anyway). I just soak them longer (basically till they start to float off the paper by themselves), and am more careful not to pull or crack them if they are somewhat brittle (which decal softener helps). Or you can get somebody's 1/72 Zero kit (like Hasegawa's) and use any spare decals you might find in it.
The irony is that a good Hasegawa Zero kit in that scale is only about $5.00 cheaper then the 1/48th Revell kit, which of course has much better detail then the old Airfix.
Hope that helps.Smile [:)]
TomCowboy [C):-)]
Tom TCowboy
    January 2007
Posted by Intruder38 on Tuesday, February 13, 2007 9:16 AM
I do have several of the Hasegawa Zeros in my stash as well and, never having been opened since I purchased them, the decals look to be in good shape. I may just have to start playing leap-frog with the decals. And your point about going to 1/48 is well-taken; the size will be more compatible with my aging physical resources. I do have a couple of them in my stash that I just couldn't resist. Once I get past this Val, I will try my hand.
