Here's what I do, based on advice from this forum and Paul Boyer's wonderful articles on this subject over the years. I use Micro Set and Micro Sol as my decal setting and "snuggling" solutions:
Use the Micro Set first. Then coat the decal with Micro Sol (if needed). The Micro Sol will cause the decal to wrinkle. Don't panic! That's normal, and the decal should snuggle down to the model's surface nicely. Don't touch the decal while it's wrinkled.
Here's the sequence I use from bare plastic to painted and finshed:
What I'm doing looks more like this:
- Prime (usually with a flat spray enamel)
- Paint (usually with Testors MM Acryl paints)
- Future (can be brushed as well as sprayed)
- Micro Set -- use a brush and put small puddle of Micro Set where the decal is going to go.
- Decal -- only soak the decal for a few seconds in warm water -- just enough that it starts to slide from the backing. Then use a moist q-tip to slide it onto the model. I sometimes nudge the decal with a toothpick too, but I'm careful to not tear it.
- Micro Sol (while decal is still wet -- about 10 min. after putting decal down).
- More Micro Sol -- for decals over raised detail. Repeat as needed until the decal is really snuggled down. Poke pin holes over air bubbles and apply Micro Sol on them too.
- Future -- for a gloss over coat. Tamiya flat base can be added to the Future to make a semi-gloss or flat top coat, but I've not done that for my models yet.
Of course, leave plenty of time for drying between most of the steps. Steps 4-6 can be done in about 10 minutes per decal, but the rest of the steps require some drying time.
One key is to not soak the decal for more tha a few seconds in the water. Take it out, and let it sit for a few more seconds before putting it on the model.
I don't profess to being a super modeler, but you can see how the Micro Sol helped the decals on my Glencoe MB-2 snuggled down into the (somewhat overdone) rib detail on the wings. It also helped the decals wrap around the back of the rudders.
Regards,
